In need of help with pc building
Sukkula
14
Hello! Im going to build my first pc build in a few months! Im new in the pc building thing. I'd like to ask if anybody knows does my 450w power supply support these parts and are they compatible:
Intel core i5-6600 3,3GHz
Asus GeForce GTX 1060 DUAL -näytönohjain, 6GB GDDR5
Asus H170M-E D3, LGA1151, Intel H170, DDR3, mATX
And I'd like to ask do those parts fit into this case: http://www.corsair.com/en-gb/carbide-series-spec-01-red-led-mid-tower-gaming-case
And one more kinda stupid question: can i take the ram out of my current motherboard and put it into my new motherboard?
Thanks in advance!
btw, sorry for wrong category :/
First off, what motherboard do you have? Even though you have a DDR3 motherboard, there could be issue where your processor may not work properly. I have seem cases where it works jsut fine. Just know Intel does not support DDR3 memory.
As far as the case goes, it should fit with no problem. And the power supply should be just fine.
So, should I get ddr4? I just know that ddr4 is more expensive than ddr3. Thanks in advance!
Well the motherboard has DDR3 slots, so DDR4 wouldn't work. However like I said Intel doesn't support DDR3 on 6th CPUs (i.e. i5-6600). I would just get a nice H110 board and call it a day. Something like:
CPU: Intel - Core i5-6600 3.3GHz Quad-Core Processor ($211.69 @ SuperBiiz)
Motherboard: MSI - H110M Gaming Micro ATX LGA1151 Motherboard ($51.98 @ Newegg)
Total: $263.67
Generated by PCPartPicker 2017-06-07 13:33 EDT-0400
Not sure what country you are in, but you can adjust the prices per your country.
Okay, so if i get any motherboard which supports 6th CPUs and ddr4 it should work fine? And is kingstons ram good on this build? I know these might be the stupidest questions you might have heard but i wanna be sure about this.
Many thanks to you!
No worry about the question. I'd rather you ask now then come back next month saying your parts don't work.
But yes, Kingston should be just fine. I believe the FURY series are probably the best in that brand. Corsair, G Skillz, and PAtriot are go to brands for RAM.
Well, the motherboard I linked is one of the cheapest ones there where im going to order my parts. And many thanks for helping with all this. Without your help I probably would have given up. Have a nice day!
Hey. One more question. I was thinking can i take my old hard drive to the new pc? Its "sata III 6,0GB/s.
Hey again... I was looking at the parts and noticed that the case has many fans (if i understood right) and was thinking can my current psu (http://www.corsair.com/en-gb/vs-seriestm-vs450-450-watt-power-supply) handle it all or should i just go with this one (http://www.corsair.com/en-gb/vs-seriestm-vs650-650-watt-power-supply). And the other reason for this question because i suck at looking the size of the case and the parts. Just so many of my friends have bought too big parts for their case and i dont want to do the same mistake. Thanks for your time!
Latest posts
