In need of monitor help
phillylol
98
ok, so im unsure where to place this post.
Anyway, the question is that im using my 1080p TV for a monitor but it's not displaying it as 1080p. How can i change this.
Go to your device manager and tell us what version of drivers you have installed for your display device. Also knowing which graphics card you have will help if you're outputting from there. If you're outputting from the mobo directly then you need to check the onboard graphics driver from your cpu.
This probably won't do anything but, you can try using another cable (dvi instead of hdmi or vice versa) or plugging in to a different port on your tv if there is one availalbe. Might just be the cable you're using on the port but I highly doubt it cause you are getting an image...
