In need of PC help
Feb 18, 2018
Greetings,
I'm having problems regarding my current pc.
1. When it has been turned on for an hour or more, then when I turn off the pc and turn it on again it boots but black screens and nothing happens, but the pc is running. This is usually fixed by unplugged all power and waiting some time and then it works normally again.
All fans are running, but it seems like GPU fan is not running the preset speed. I have a motherboard speaker, but it is not indicating any error.
2. When in game the pc is not 'stable' regarding frames or performance and it varies a lot. This being CS:GO, PUBG, Cod WW, H1Z1. PUBG is the worst performing, with frames going up and down.
My current rig:
I5 7600k, not overclocked since I got it, since the problems above have been happening.
MSi 1060 oc 6gb dual fan (had this in for an rma since I thought this was the problem - it was not)
Benq XL2411 24", connected by dvi-d
MSI z270-a-pro motherboard
4x HyperX FURY DDR4 2400MHz 4GB
2 x Samsung 850 250 gb ssd
Fractal Design Focus G ATX, with 2 front fans. 2 other Corsair fans equipped afterwards, 1 upwards 1 backwards.
Corsair CX600M (this one is the only one, that I didn't buy with all the above, since I took this from my old pc and used with the parts above.)
Temps:
CPU max 64, PUBG medium settings - always running fan at 100%
GPU max 63 PUBG medium settings - fan at 85-90%
All other fans are running 100%
Reapplied new thermal paste - Arctic MX-4
BIOS is updated, same is GPU, audio and all other updates dones through windows and MSI Live update.
I'm in need of help, since the lack of performance and weird startup-black screen is driving me crazy. This build feels worse than my old gtx 660, i5 4670 8gb ram build.
Hope somebody can help, thanks in advance! /Mikkel
