In need of urgent PSU help
Shaun98
462
Hello, I've just had my evga supernova 850w PSU delivered and have removed my old PSU but can't figure out were everything connects with my new PSU
There are multiple sockets on my board some say jlp1, jtmp1, jfp1 etc and I have no clue what goes there...
My board is a and fx 6300 if that helps!
If you can help me out it is much appreciated as I'm completely lost xD
the board you posted is the processor and does not help unfortunately. on replacing PSU's there are really only a few connectors that you need to be aware of. 1. is the 20+4 pin connector to your motherboard. 2. is the 4 or 8 pin connector for your Processor (CPU) that also connectors to your motherboard 3. are the connectors to your graphics card known as PCI-E power connectors or 6 or 6+2 pin connectors 4. Is the connectors to optical drives (dvd, bluray cd-rom) and storage drives (Hard drives, Solid state drives) now days they should all be sata power connectors. you can google any one of those connectors and it will show you where they go and what they look like.
There is also youtube. I was going to refrain from mentioning it due to your pc being in dis-order but then promptly realized you have internet... obviously... sorry had a big lunch and well i feel like i need a nap.
Ok it takes a 8 pin cpu connector and the 20+4 pin for the motherboard. don't forget to replace the connectors to your drives and graphics card if you have one. (TLDR) if it fits with-out the need for force it probably goes there.
24 PIN AND 8 PIN in yellow.
8 pin is CPU power , 24 pin is board power.
Its my case LEDs and power buttons etc that are getting me lost. Got most stuff in but there's 3 little rectangular cables with 4 small pins that all go in the same port and I think its my case LEDs and screen and power
