In/out fan arrangement in my case
G
Guest
Guest
My case: http://imageshack.us/photo/my-images/6/1000251c.jpg/
http://www.coolermaster.com/upload/product_feature/Web-430.jpg
Out fans:
80MM Exhaust fan 1 (right side of picture): http://imageshack.us/photo/my-images/163/1000250k.jpg/
120MM Exhaust fan 2 (back of case): http://imageshack.us/photo/my-images/705/1000249q.jpg/
In fans:
120MM Intake fan1 (on side panel): http://imageshack.us/photo/my-images/801/1000246b.jpg/
80MM Intake fan2 (bottom of case): http://imageshack.us/photo/my-images/32/1000245m.jpg/
Cpu fan:
120MM CPU fan: http://imageshack.us/photo/my-images/152/1000247c.jpg/
Is this a good setup or is there something better I can try?
Do a measurement of temps over say an hour with the fan where it is, then move it and repeat, keep whichever give you the best temps,
sorry for what seems like a copout answer there, but identical setups in different environments will behave differently, what works on mine may not be optimal for your room
personally I'd have both top slots occupied, not just the one
Moto
G
Guest
Guest
Got it. Should I move the top exhaust fan close to the rear exhaust fan or leave it as is? The reason I ask is it's right beside the cpu fan.
Moto
