Question In regards to overclocking and heat production
punkncat
Commendable
Apr 3, 2018
1,433
92
1,540
81
I have tried to read as much as I can about OC'ing here and other sites. I have found that I completely understand parts of it, and others not so much....but with the reading I have done I have successfully and have stable OC higher than I have been able to achieve before. I read guides specific to my motherboard and CPU which was really helpful.
I was curious about one aspect.
If you OC and the voltage isn't high enough I know it can lead to instability, which I understand. If the voltage is too low does it also generate MORE heat, not less?
punkncat
Commendable
Apr 3, 2018
1,433
92
1,540
81
No, voltage too low would produce less heat.
This is what I thought, so riddle me this....
I am OC'ing on a R7 1700 ASRock Taichi X370 on a Cooler Master Hyper 212 Evo. Two intake fans, two exhaust fans. Using Prime95, CPU-Z, and Cinebench 15 to test.
If I set to anything above 3.5/1.2150 volts it will "act" ok until I run a stress test or more specifically run a certain game. The core temps run up past mid 70's and then shutdown. I had it set at 3.8/1.34 ran fine all winter and suddenly it would overhead and shut down. When "warm" out my ambient is 74F in the house.
Just for the heck of it I tried 3.9/1.4 and it benches perfectly, gets no hotter than 70C. Even in the certain game, the highest I saw was 67C which it was surpassing on the 3.5 OC.
Not really sure what's going on as I haven't gotten so deep into it as to change advanced settings in the BIOS.
punkncat
Commendable
Apr 3, 2018
1,433
92
1,540
81
In game it's usually a slight stutter then hang, game crashes return to desktop where it may or may not be hung. Sometimes black screen restart. When running a bench it is more often "your pc" blue screen restart.
punkncat
Commendable
Apr 3, 2018
1,433
92
1,540
81
Well, apparently I am just not meant to OC this chip.
As above it ran fine for several days. Was on 3900ghz, 1.4 V with the RAM set at 2933 OC on the Taichi. Was playing a game and the system blue screened. I restarted, ran a few tests and temps were quickly jumping to ~83C and lockup/shutdown. Ended up that I am having to run the proc at stock clocks on "auto" and can only run the RAM at 2800 or it will BSOD.
I actually swapped to this motherboard thinking that the previous mobo VRM were the problem. It seems there is something more at play. I have incredible headroom for more temps on the stock clock. I can't make it reach 60C with any test on the current cooler. The moment I put any manner of OC on it wants to climb till shutdown.
Come on Zen2
