Hey everyone, as the title says I'm in the market for a new SSD and I just realized that the second PCIe slot is gen 2. I'm looking at a few 2tb SSDs since those seem pretty affordable and will likely fix my storage issues for gaming. Some of the options I have in my list are the Western Black SN770, TEAMGROUP MP33, and Crucial P3, all of which are gen 4, gen 3, and gen 4 respectively. My PCIe gen 2 slot has 4 lanes and all of the options I gave have 4 as well, I know that newer gen SSDs can work with older ones but I'm not sure if the amount of lanes matters when installing. For instance, if I were to use an m.2 with 8 lanes but my PCIe slot only has 4, will it still work? Going back to what I was going to ask, would it be best to buy a gen 2 SSD for a cheaper price than one that's gen 4 instead? I feel it's better to just get a newer SSD and just upgrade my mobo later, but I figure I get a little help if anyone is willing to give their opinion or knowledge, it is appreciated. Also the m.2 I have installed already is in the PCIe 3 slot, I figure I should mention that.
Specs
Edit:
looked up my current m.2 info and it would fit perfectly in the PCIe slot instead, so I could fit one of the three mentioned SSDs into the gen 3 PCIe slot.
Edit 2:
Just learned the difference between a Sata SSD and a NVMe SSD, trying to find if my mobo is compatible with with NVMe SSDs. If anyone has any insight that'd be appreciated.
Edit 3:
I did some more research and saw that the Gen 3 m.2 slot should be compatible with a Gen 4 NVMe m.2 because it is able to support M key m.2s. So hypothetically if I were to move my current SSD to the PCIe slot my computer should run normally yes?
Edit 4:
After some more research I determined that the Western Black SN770 is the fastest while being cheap since it's on sale atm on amazon. If anyone has another recommendation I'd like to hear.
Specs
- CPU - Ryzen 5 5600
- GPU - GeForce RTX 4060
- Motherboard - x470 Aorus Ultra Gaming
- RAM - I'm not sure what exactly they are but they are 2 Corsair 8gb sticks with a speed of 2133 MHz
- Power - 650 watt
- Current M.2 installed in PCIe slot - Samsung 860 Evo 500 gb
Edit:
Edit 2:
Edit 3:
Edit 4:
