Inaccessible boot device bsod after plugging/removing USB flash device
reuvpro
Hey there I have a problem that happen only in windows 10 when I trying to safely eject the USB it says that the USB device is already in use (which is not )and if I'm removing it forcely the pc freeze and I'm getting the bsod with the error: inaccessible boot device and then my pc turning off I tried to format but it still happing I had no choice to go back to win 8.1 and there everything good (also it happing with some USB devices but some are working to but still ..I want to fix it)
what should I do cause I really want win 10... Tnx
Hello again reuvpro
In that case, you can try uninstalling the USB driver from your computer from the Device Manager and then letting Windows 10 install the correct drivers automatically. To do so:
> Right-click the Start button.
> Click Computer Management.
> From the left pane, click to select Device Manager.
> From the right pane, expand the...
its not matching the problem i have.. i dont know whats wrong in win 8.1 all of the usb flash devices worked but now in 10 some working fine and some not working at all .. for example after removing the usb stick its shows the devices are still connected but they are not!
and sometimes after removing the usb it bring the bsod with iaccessible boot device error..
Hello again reuvpro
> From the right pane, expand the Universal Serial Bus Controllers tree.
> Right-click each USB controller individually, click Uninstall from the context menu, and then follow the on-screen instructions to uninstall the controller.
> Restart the computer when done and let Windows install the default USB drivers automatically.
Hope this helps.
Cheers!! :)
May it be that your Sata Mode is correct? Try to boot in different S-ATA Modes! If that´s the Problem, you could reinstall the OS or go to regedit and delete the sata override... you may find it at the Internet. I did.
Can someone please help me
I have tried multiple times to clean install windows 10. Ill format the partions make sure nothing is there. When I install it it will actually finsh setup and get me to a desk top but as soon as I unplug my bootable USB and restart it gives me the inaccessible_boot_Device error. I dont know what to do
Can't boot into safe mode
Can't use CSM in bios because my bios doesn't have it.
Someone please help!
