Incompatible 32 bit program in Windowds 7 64 bit
joesmithy
44
Hi there, recently I installed a Buffalo Wireless-N Ultra Compact USB 2.0 Adapter in my computer to connect to my wireless router. The problem is I did not see that the installation program is only supported in Windows Vista 32 Bit or Windows XP. Is there anyway through command prompt or its setup ini file that I can bypass this, or can I just plug in the adapter without installing the program?
The website for the installation is here: http://www.buffalotech.com/support/downloads/nfiniti-wireless-n-ultra-compact-usb-20-adapter-wli-uc-gn/ in the CD Image
Here is the specifications: http://www.newegg.com/Product/Product.aspx?Item=N82E16833162030&Tpk=buffalo%20ultra-compact
Thank you for your help!
