Hello everyone,
I appreciate you taking the time to read this and provide your input. I recently built my first PC.
The motherboard I am using is the ASUS Z170 PRO GAMING LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 USB 3.0 ATX Intel Motherboard
The memory I have installed is the G.SKILL Ripjaws 4 Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000) Intel X99 Platform Extreme Performance Memory Model F4-3000C15D-16GRBB
After updated my bios, I noticed that the memory speed in the bios is set to 2133. If I try to increase the memory frequency to 3000, the PC will reboot, turn on, but will not post. In order to get the PC to post (clearing the CMOS doesn't seem to work), I have to remove one of the ram sticks, allow the system to boot and detect the new ram configuration, shutdown, reinstall the second memory stick, and reboot again. This works, but I am again stuck running at a frequency of 2133.
I noticed that the compatible memory list, according to Asus for the mobo, does not include seem to include my exact model number of ram.
I am assuming I have ram that is not compatible with my motherboard? Another possibility could be the recent bios update, as I don't remember noticing this discrepancy before. Would it be smart to downgrade the bios, and give that a try?
Also, as a side note, if I attempt to adjust the ram in anyway, so far (as in overclocking, etc), the PC won't post and I have to perform the steps above.
Thanks so much for you help!
