Question Incorrect volt sensor reading on CPU?
May 2, 2022
45
https://gyazo. com/792cd6aa71c244440c4d4c1c66627936
Trying to learn overclocking, the idea is to set it to run at 3800mhz, 1.375v Core voltage and 1.1v SoC voltage. A few posts say any SoC voltage over 1.15 is dangerous.
On the picture above you see a Ryzen Master overclock, I also did the same in BIOS overclock and the SoC VDD voltage is exactly the same, even though I did set it to 1.1v, what's going on?
Excuse the link, that's the only way the website will allow me to post it, otherwise it's "spam content".
Better to describe it in words.
Which MB and CPU ?
Depending on CPU 3800MHz could be just underclock and depending on MB, manual OC may not be possible.
With Ryzen in most instances it's best just to limit auto voltages by negative offset and let it scale up and down as needed by load.
Which MB and CPU ?
Gigabyte B450 Elite V2
Ryzen 5 1600
