based on the research i did, FSB is multiplied by 4. so my CPU's FSB is 1066MHz rated, which is 266.66 effective.
i have DDR2 800 RAM which, is supposed to be 400MHz effective.
from what i understand, this would mean that my RAM is 133.33MHz faster than what my CPU FSB is, which technically creates a bottleneck on the FSB.
my motherboard has the ability to overclock CPU FSB without the RAM overclocking, i can also change my CPU multiplier.
i have the Intel C2D E7400 which is 1066 FSB with a multiplier of 10.5 at 2.8GHz, all stock.
would i be able to up the FSB but reduce the multiplier to get closer to a 1-1 ratio on my FSB without needing to increase other stuff like voltages?
ideally id want to go to, say 1400 FSB, and change the multiplier to 8, which would also be 2.8GHz (350MHz times 8, but at a much higher FSB. would this be doable or would other issues arise?
i would think no, but i dont know enough about overclocking to know and i dont want to test something like this in case something fries.
feedback on this would be greatly appreciated. thanks guys
