Hi!
Is it possible to connect a single RGB LED to a motherboard header? Aquacomputer has an RGB Illumination module: https://shop.aquacomputer.de/product_info.php?products_id=2664. Barrow has an RGB plug also: https://freezemod.com/product/barrow-g14-thread-acrylic-led-light-water-sealing-lock-end-plug-ygy-01/
I don't know if it is possible to control these via the mobo. Or if any other product exist which is compatible with the headers.
My plan is to illuminate the reservoir and the GPU water block with 2 single LEDS.
Thanks,
Oliver
Thanks,
Oliver
