Info On Fitting EVGA Classified 3-way SLI On A Microcool Banchetto 101
G
Guest
Guest
Hi guys,
Looking to see if anyone has attempted to fit a EVGA Classified 3-way SLI on a Microcool Banchetto 101 Clear Modular Case.
The E-ATX, Will it cover the power and rest switch? Also, is there anything else to know about this combo before purchasing the case. I already have the M/B. If the M/B covers the switches is there still room to get to them? If anyone has tried or has info on this please let me know what you think. Thanks...
G
Guest
Guest
Thanks for the response. I just don't know how much room i have to spare with the power and reset switch. Thanks again. ;)
G
Guest
Guest
jgdsl, I have yet to order it. I have sent an e-mail to the manufacture to find out the distance from the switches to the rear of the top plate. Need to know if the M/B will cover the switches. So, I don't know if it will fit. :( If you have any info regarding this please send it my way. Thanks again ;)
gravlin
23
that MB is a EATX form factor and is very Big I have one my self. You need a full tower case that supports EATX MB.
Most full towers do
IF it is not a full tower case then it probably will not fit.
