Inforce Develops a Pico-ITX System with Snapdragon S4 Pro
ATX/ITX are just form factors that specify board sizes, mounting hole locations and power connector pinout/voltages.
If you design electronics and do not want to make a custom enclosure for it, you can build it to ATX/ITX/whatever spec to make it fit in a standard box instead of designing your own enclosure + mains PSU. It may be based around an ARM CPU, Power CPU, T4 CPU, FPGA or whatever else... heck, it could even be a non-digital device like an amplifier or just a space heater disguised as a PC.
You can put whatever you want in those boxes. The standards are only intended to make enclosures mechanically and electrically interchangeable with minimal hassle.
atx/itx is a form factor standard. as long as it fits, you can cram anything there.
