• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
Inline fill/drain valve idea
tougas
351
5
So i have an idea and in my head it functions im just wondering if anyone has pulled it off before. So my idea is to put a t connector at the low point in my loop. off of the T i would have an on/off valve. Then i would make a fill/drain hose that has the bard the will screw into the on/off valve. This way when i need to drain my system i let the drain hose hang and it will be lower causing the coolant to drain and when i need to fill i simply hold the hose above the case and pour in the coolant. Any opinions? As for placement, if the concept is sound, what would be best?
Plumbo01
I too was astounded at the results we have a tendency to saw at the shoopbot camp when bill let us strive our hand at it. There was one piece there that gave the look of an old brass item, then you pick it up to understand its a piece of foam!
The only way to tell your half isn't a piece of rusty steel would be to choose it up.
scopey86
306
21
Uhh...what? Lol Plumbo01
Like delluser1 said, you can't use the drain port to fill as well even if you hold it above your loop, it still goes down to the bottom without getting anywhere else. Either use the top of your res as a fillport (with a QDC) or use a fillport.
Thread starter Similar threads Forum Replies Date
S Overclocking 4
C Overclocking 1
Similar threads
