Question Inno3D RTX 3060 Ti TWIN X2 OC 85 degrees max temperature with undervolt
Amaterasu12
Commendable
Jul 3, 2020
6
So, from the beginning the card maxed out at around 88 degrees. I have 2 120mm fans as intakes on the front, 1 120mm exhaust at the top and 1 120mm the back. Custom fun curve did not make any difference. Undervolt got me to around 82-85 degrees. With open case it stays at 81 degrees max. My idle temps are 37 degrees. Honestly I have tried everything except changing paste which I wouldn't prefer to do, plus I don't see the point on doing that as I bought the card 1 year ago. Every guy on the internet gets 75 degrees max on this card so i don't get what's happening with mine. Is it normal? Should I try something else? Any help is welcomed. P.S.: No warranty
Amaterasu12
Commendable
Jul 3, 2020
6
What is the ambient room temperature where you stay ? I wouldn't worry much the GPU shooting up to 81c though, if that's under full gaming load, but your IDLE temp is actually a bit high imo.
its around 23-25 degrees now that is summer. But this is happening in winter as well with 17 degrees ambient temperature. I agree 81c is okay but I would prefer not to have my case open. Really is 37 high for idle? Hotspot is 49c on idle. Oh and the fans are working 90% but they blow very little hot air under load, like the heat is not dispersed at all. Backplate is very hot.
Phaaze88
Ambassador
Some more information would be great, like:
-What is the case? Bonus points if a couple pictures are included. Please remove the side panel before taking pics of the interior; glass paneling blurs images and shows certain reflections.
-What is the temperature gap between the gpu core and the hot spot when the gpu is under load?
Phaaze88
Ambassador
- My case is the Cougar MX-330G. Here are the photos as well:
https://quickshare.samsungcloud.com/oquYXRFMdxvV
- the difference is mostly 15-16 degrees. For example I did a stress test now and GPU core is 82c and the hotspot was around 97c .
The 2nd cpu cooler fan IS facing the same direction as the rear case fan and the 1st cpu cooler fan, right?
I can't really tell from the pictures.
15-16C is a pretty good gap between the 2, so no repaste is needed here.
Evidence so far points towards airflow: gpu exhaust.
1)INNO3D's shroud is obstructing airflow - at least, it looks that way to me - particularly at the 2nd half(rear) of the card.
2)Your PCIe cable looks like it would do the same to the other half - I know there's the small pass-through, but most air cooled models also exhaust their waste heat from the sides. I figure you did it that way because the case is a bit narrow.
You might be best off using an old DIY method: removing that shroud and zip-tying a couple of 92/120mm case fans to the heatsink.
Amaterasu12
Commendable
Jul 3, 2020
6
My problem in the first place was that everybody who benchmarked this card on you tube and stuff they
were getting 75 degrees. Regarding the shroud, unfortunately is a little out of my expertise to remove it, so I probably won't bother. But generally I don't have an issue with the temperatures (like 82-85 degrees) as long as they are normal and won't harm the GPU. I mostly wanted to see if it was a thermal paste issue but from what you are saying it's not.
-Oh and yea the 2 cpu coolers and the rear case fan are exhausting to the back of the case.
Phaaze88
Ambassador
Don't take what you've seen on youtube, etc, about that as a baseline, a commonly made mistake.
In this case(pun), their 75C vs your 82-85C could be caused by:
-front fans in the MX-330G are sandwiched between mesh. Effective airflow likely weaker than if the fans were only behind mesh instead.
-the fans and fan setup in your case vs the fans in the others' cases.
-heck, even the case used can be a factor - in terms of its design.
-or some combination of the above.
Another factor is if you're dealing with higher ambient temperatures. Peak and low load thermals will of course be higher. I think many reviewers do thermal tests around 20C room ambient in an air conditioned environment. The case ambient will always be warmer than that - if a case is even being used.
Aye, it's far from a paste issue. It's bad when you see like a 25C gap between core and hot spot.
Amaterasu12
Commendable
Jul 3, 2020
6
okayy I see.. I will do nothing further then, except maybe sometime in the future I will move the fans behind the mesh. You saved me some serious cash because I was ready to buy thermal paste,pads, eletric screwdriver etc. Really thanks for all the interest and the help!
Reactions: Phaaze88
