[SOLVED] Input not supported after trying to reset Pc
bferguson4
15
I decided to reset my pc to try to fix a problem with Windows. While trying to reset the pc, a problem occurred causing no changes to be made. So, I tried to reset with the use of a recovery USB. This also had a problem causing no changes, however I couldn't exit back to Windows 10. I tried restarting and hard shutting down which lead me back to the previous screen. Eventually, I restarted my pc and on the reboot my monitor displayed "Input not support". Now, when I boot up my pc my monitor displays "Input not supported". To fix this, I tried to open up BIOS and Safe Mode which didn't work. I'm curious to find other solutions for the problem.
specs
Monitor: Acer SB220Q bi 21.5 inches Full HD (1920 x 1080) IPS Ultra-Thin Zero Frame Monitor (HDMI & VGA port)
RAM: 2*CORSAIR Vengeance LPX 8GB (1 x 8GB) DDR4 DRAM 2400MHz C16 (PC4-19200) Memory Kit - Black (CMK8GX4M1A2400C16)
CPU: AMD RYZEN 5 1600X 6-Core 3.6 GHz (4.0 GHz Turbo) Socket AM4 95W YD160XBCAEWOF Desktop Processor
GPU: XFX Radeon RX 580 GTS XXX Edition 1386MHz OC+, 8GB GDDR5, VR Ready, Dual BIOS, 3xDP HDMI DVI, AMD Graphics Card (RX-580P8DFD6)
Motherboard: MSI B450-A PRO AM4 AMD B450 SATA 6Gb/s USB 3.1 HDMI ATX AMD Motherboard
SSD: WD Blue 3D NAND 500GB PC SSD - SATA III 6 Gb/s M.2 2280 Solid State Drive - WDS500G2B0B
Hard Drive: WD Black 1TB Performance Desktop Hard Disk Drive - 7200 RPM SATA 6Gb/s 64MB Cache 3.5 Inch - WD1003FZEX
Are you unable to boot into Safe Mode? Just for information, what was your original problem which made you decide to reset?
This problem has been known to occur with Acer monitors where the system is set to an incompatible resolution/refresh rate. The fix is to boot into Windows in Safe Mode and change the resolution and refresh rate to your monitors native values (1920 x 1080 @ 75Hz).
Yes, I am unable to boot into Safe Mood. And the problem was I lost important files in WindowsApps trying to transfer it to my Hard Drive from my SSD
