Input on a Build
FarmerTed
39
Hey guys. Looking for some input. Got some help with my very first build a couple years ago.
Here's where I am at. I want to take things to the next level. Gaming at 1080p is now no longer all it was made out to be. Plus I'm looking into building a custom water loop. I plan on getting gsync enabled monitor (asus rog swift) or a freesync monitor. I have researched pretty extensively each of those. I have several builds in mind, but I want to see what you guys come up with. This rig will be for gaming and streaming. I don't do much else on it. (I play bf4, HoTS, crysis 3, and many more). I want a rig that will game at 1440 with good sustained fps.
I'm not sold on any particular side (amd, or nvidia). I'm particular to Intel for cpu but when you go higher end, Intel is usually suggested with the territory. Budget 2k not including monitor or peripherals. I could probably go higher than 2k. I'm at least giving a basis. I'm all ears because I'm at crossroads for gpu,f freesync, gsync, and etc. Throw your builds and suggestions at me and try and convince me that you have the answer.
TL/DNR: gaming rig for 1440 gaming with good fps. 2k budget (could go higher) not including monitor or peripherals.
How about waiting for the 300 series from AMD? Do you already have the monitors? Also would a 1440p and a 1080p monitor work?
If you don't want to wait=
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($324.99 @ SuperBiiz)
CPU Cooler: Phanteks PH-TC14PE_BK 78.1 CFM CPU Cooler ($79.99 @ Amazon)
Motherboard: ASRock Z97 EXTREME6 ATX LGA1150 Motherboard ($150.98 @ Newegg)
Memory: G.Skill Ares Series 16GB (2 x 8GB) DDR3-1600 Memory ($99.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($109.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($52.75 @ OutletPC)
Video Card: MSI GeForce GTX 980 4GB Video Card (2-Way SLI) ($531.98 @ Newegg)
Case: NZXT Source 530 ATX Full Tower Case ($89.99 @ Amazon)
Power Supply: EVGA 850W 80+ Bronze Certified Semi-Modular ATX Power Supply ($82.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($87.95 @ OutletPC)
Total: $2143.58
Generated by PCPartPicker 2015-03-29 22:33 EDT-0400
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($28.98 @ OutletPC)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard ($100.98 @ Newegg)
Memory: Kingston Beast 16GB (2 x 8GB) DDR3-1600 Memory ($126.74 @ Amazon)
Video Card: EVGA GeForce GTX Titan X 12GB Video Card ($999.99 @ Amazon)
Case: Phanteks Enthoo Pro ATX Full Tower Case ($99.99 @ Amazon)
Power Supply: EVGA 850W 80+ Bronze Certified Semi-Modular ATX Power Supply ($62.99 @ NCIX US)
Total: $1907.40
Generated by PCPartPicker 2015-03-30 13:45 EDT-0400
Throwing a titan in there sounds interesting. I hadn't thought of putting a titan in the mix. My thought was that 980 in sli later might be better than a titan x. Anyone have any thoughts on that?
The build that I have suggested already has sli 980's.
What's your budget for the monitor? Also I am asking this again= Why not wait for the 300 series from AMD? By the time they are released some more free-sync monitors would have been released(I am only taking a guess here).
