Input signal out of range, please change settings to 1280x1024-60Hz
Feb 6, 2018
9
^Every time i turn on my 2nd monitor this message shows up^
When the screen i turned on the screen is small and blurry, and after a few seconds of the message appearing the monitor turns off.
Here are the things i have tried to fix it:
* i tried installing the newest windows 10 software and drivers
* i tried re-rolling the radeon 7900-series driver.
* i tried changing the settings to 1280x1024 - 60Hz
* i tried restarting the pc.
So far none of these things have helped, so i'm just wondering what i should do to fix it.
Monitor (HP L1706) specs gotten from Radeon AMD software:
Horizontal Timing Total - 2160
Horizontal Timing Display - 1600
Horizontal Timing Front Porch - 64
Horizontal Timing Sync Width - 192
Vertical Timing Total - 1250
Vertical Timing Display - 1200
Vertical Timing Front Porch - 1
Vertical Timing Sync Width - 3
Horizontal Timing Polarity - Positive
Vertical Timing Polarity - Positive
Interlaced/Progressive - Progressive
G.Pixel Clock (KHz) - 162000
G.Refresh Rate (Hz) - 60
Current HDCP Status - Disabled
Current Link Settings - Not Available
Monitor 1(works perfectly) : BenQ RL2450
Horizontal Timing Total - 2200
Horizontal Timing Display - 1920
Horizontal Timing Front Porch - 88
Horizontal Timing Sync Width - 44
Vertical Timing Total - 1125
Vertical Timing Display - 1080
Vertical Timing Front Porch - 4
Vertical Timing Sync Width - 5
G.Pixel Clock (KHz) - 148500
Thanks, i have already checked out this website, and it only has drivers for vista and xp
My 2 monitors have different ports, 1 has hdmi and one has vga, so i can't plug in a different slot.
Now i did some testing and it turns out i can run the 2nd monitor just fine if the 1st isn't connected. In fact the only mode which does not work (when clicking windows key + P) is the extend displays. so the monitor works just fine on it's own.
I don't know if i've tried windows drivers, as i don't know where or how to download them.
When you say reboot, do you mean reboot the pc to fabric data?
I have not tried the Guru3d driver sweeper.
I have no idea, if you tell me how to find out i will :)
thanks for helping me out
will this be sufficient?
Radeon Software Version - 18.2.1
Radeon Software Edition - Adrenalin
Graphics Chipset - AMD Radeon HD 7900 Series
Memory Size - 3072 MB
Memory Type - GDDR5
Core Clock - 925 MHz
Windows Version - Windows 10 (64 bit)
System Memory - 8 GB
CPU Type - Intel(R) Core(TM) i7-2700K CPU @ 3.50GHz
Graphics Card Manufacturer - Powered by AMD
Device ID - 679A
Vendor ID - 1002
SubSystem ID - 3000
SubSystem Vendor ID - 174B
Revision ID - 00
Bus Type - PCI Express 3.0
Current Bus Settings - PCI Express 2.0 x16
BIOS Version - 015.029.000.002
BIOS Part Number - 113-1E249100-S41
BIOS Date - 2012/12/13 00:33
Memory Type - GDDR5
Memory Clock - 1250 MHz
Total Memory Bandwidth - 240 GByte/s
Memory Bit Rate - 5.00 Gbps
2D Driver File Path - /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/Class/{4d36e968-e325-11ce-bfc1-08002be10318}/0000
So, your monitors work now?
1. Download the driver from AMD:
https://support.amd.com/en-us/download/desktop?os=Windows+10+-+64
2. Download the 3D Guru Uninstaller
3. Run the uninstaller and select AMD in the options. Follow instructions, they are pretty easy to follow. PC should restart.
4. Install your downloaded drivers and reboot PC.
You will have latest AMD drivers installed. In your AMD control panel/driver opetions you will have to tinker with settings to enable 2 monitors. Remeber, a CLONE monitor = same information on the 2nd display, so probably chose extended view or whatever it is called in the AMD software.
let me know how it works.
Thanks, i got a new problem though *sigh*
This should be easy to fix, my screen is larger than the monitor, so i can't see the entire screen, can't find any settings for it on the monitor itself, any tips?
Edit: It got fixed somehow, thanks for all your help :)
