Hey Guys,
Just want to start off by saying I'm completely new here and would have never even thought of building my own computer until a couple of days ago. Sorry for the wall of text 😀
A little back story if anyone is interested - Skip down to the "Main uses..." section for the actual build info.
I've always had second hand computers that I've purchased cheap off a friend who builds his own. He'd get something new and I'd buy his old one. The current one I've had for about 4-5 years and the PSU died on it a few days ago. My first reaction was to contact him and ask him to build me something. Then I figured, how hard can it be to replace the PSU. I knew absolutely nothing about about how to even find a compatible part so I spent several hours googling "how to replace a PSU" and understanding all the different connections etc that were needed. Needless to say, it was no where near as difficult as I thought it would be and managed to replace it and everything is back up running fine.
My current computer is quite old (Specs below) and obviously isn't that great by todays standards for gaming, photoshop/illustrator etc.
UserBencmarks: Game 15%, Desk 23%, Work 14%
CPU: Intel Core2 Quad Q6600 -22.2%
GPU: Nvidia GTX 460 - 14.3%
HDD: WD Blue 320GB (2008) - 42%
RAM: Unknown 2x2GB - 12.1%
MBD: Asus P5N-D
Realising how easy it was to replace that PSU and how bad my current computer is, it made me think.. would I be able to build a whole new machine with basically no experience?
2 Days later here I am and super excited to make this actually happen. Around $1500 NZD was my budget so I'm pretty happy where it's sitting - With easter sales the prices were around $1350-1400 and I'm in no massive rush so would wait to get better deals where I can.
Main uses/ Things I want out of it
Gaming - I don't mind if I can't run everything on max settings. Even having them run smoothly on med-high would be amazing!
Photoshop/Illustrator - I do a bit of freelance design so having something that can handle those nicely would be good
Media streaming - Netflix, movies, music etc.
Dual display - Possibly triple later on
Pretty much just want a really good upgrade from what I have but not spending $2-3000 on top of the line components. It doesn't need to be flashy and at this stage I don't really care about all the colours and fancy LEDS although I'm sure that will change as the addiction gets worse 😀
Most of the parts I've chosen and based on benchmark performances, reviews and info I've found through Google so please let me know if I'm completely off with anything!
PCPartPicker part list: [https://nz.pcpartpicker.com/list/YRFjCy](https://nz.pcpartpicker.com/list/YRFjCy)
Price breakdown by merchant: [https://nz.pcpartpicker.com/list/YRFjCy/by_merchant/](https://nz.pcpartpicker.com/list/YRFjCy/by_merchant/)
CPU: Intel Core i5-7600 3.5GHz Quad-Core Processor ($345.00 @ PB Technologies)
i7-7700 is like $100 more and doesn't really seem a lot better.
i5-7600k is only $20 more but I don't plan on overclocking seeing as this would be my first build + would need to buy a CPU Cooler seperately.
i5-6600 only $20 cheaper and the 7600 seems like a decent step up for that price
Motherboard: Gigabyte GA-H270-HD3 ATX LGA1151 Motherboard ($205.85 @ PB Technologies)
I did quite a bit of research into the varieties. Z170/270, H110/170/270, B, Q etc. etc.
H270 seemed like a good choice.
1xx boards need a bios update for the 7xxx intel chips which I didn't want to touch.
270's seem more upgradable over the 170s and 110s
Zxx seem more of overclocking - Only $30-40 more for a Z270 if it would be worth it for other reasons though
Memory: G.Skill Ripjaws V Series 8GB (2 x 4GB) DDR4-2400 Memory ($113.85 @ PB Technologies)
8GB Ram should do me to start with. Can upgrade to 16 later if needed. Good reviews and benchmarking results
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive ($82.80 @ PB Technologies)
SSD for OS and other programs That might benefit from it. 120GB Seems to be enough to start with as the price jumps alot to the next capacity. Samsung EVO 850 seems a good choice but a lot more expensive
Storage: Seagate BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive ($78.99 @ PB Technologies)
1TB should be plenty for me to start with. The current 320GB is about 70% full so will upgrade or add more later if needed. Both WD and Segate equivalents seem pretty even in terms of reviews and benchmarks
Video Card: EVGA GeForce GTX 1060 3GB 3GB GAMING Video Card ($349.00 @ PB Technologies)
This was the hardest choice and the 1060 seems to be a decent balance of cost vs performance.
1050ti is about $100 cheaper
1060 6Gb is about an extra $100
1070 is about an extra $200
Case: Zalman Z3 Plus ATX Mid Tower Case ($90.85 @ PB Technologies)
Kind of mixed reviews - not fully set on this and may look in to it further
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($99.00 @ PB Technologies)
Ironically the hardest piece of the puzzle to find. From what I could tell it will do the job and has good reviews
Operating System: Microsoft Windows 10 Home OEM 64-bit ($171.35 @ PB Technol**ogies)
Will probably get the USB version but need to get one or the other either way
Total: $1536.69 inc GST (roughly $1080 USD)
Ill use my current monitors, KB+M, speakers etc for now and will probably replace them later on.
To anyone who has read this far, thank you so much and if you have any feedback or changes you'd make please let me know!
Thanks!
MBD: Asus P5N-D
Thanks!
