G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I am having an ongoing problem with the audio on my Inspiron 8200.
Some time ago, I noticed lack of sound upon reboot. After searching around I
found that the there was a problem installing the audio driver. I found some
references to this issue and that it might be solved by uninstalling the
Crystal WDM Audio Codec driver and then re-scanning for hardware changes.
Although inconvenient (since it needed to be repeated after each reboot)
this worked for me for awhile.
More recently, I began experiencing intermittent complete system lockup
(system unresponsive to mouse movement or keyboard interaction, display not
updating, no disk activity) which required powering the system down and
bringing it back up to make it usable again. Sometimes, however, the system
would lock up while booting windows (XP service pack 2). After many days of
struggling with this problem, I found that the only way to boot my system
and keep it running was to boot into safe mode, disable the audio driver,
and then boot normally. If I try to enable the audio driver, the system will
eventually lock up (usually within a few minutes after enabling it).
The driver I am using is 6.13.10.4159 dated 8/5/2002. When installed
properly (and when the system isn't locked up), the sound seems to work
perfectly fine. Can this be a hardware problem? If so, do I have to replace
the whole system board?
Is it worth trying the Intel driver? If so, how do I get back to it now that
the Crystal driver is installed? XP doesn't seem to find it on my system
even though it was originally used when I re-installed the OS upon getting a
new disk drive.
new disk drive.
