Hi All,
I have a problem here. I have two PC. one pc with the cd rom and another small mini pc i dont have a cd rom. how can i install winxp using thumbdrive or using LAN connection.
This is my small pc looks like only with usb connection and NIC connection.
I have a Lan connection. Is it possible for me to put in the bootable cd in my working PC and boot it using LAN connection to the other pc without using cdrom?
This is the specification of the mini PC
Manufacturer: VIA
VIA EDEN PROCESSOR 1200Mhz
Frequency : 1.20 Ghz
FSB Speed: 400 Mhz
Cache L1: 128kb
Cache L2: 128kb
System Memory : (960MB) - Connects to samsung 42 inch LCD screen maybe the rest of the memory taken up by the lcd screen.
Boot Setting Configuration
Quick Boot Enabled
Quiet Boot Disabled
LAN BIOS Execute Disabled --//// I wonder if i enable this function can i use LAN to install my win xp?
Bootup Num-Lock [ON]
PS/2 Mouse Support [Auto]
Interupt 19 Capture Disabled
Beep Function Disabled
Boot Priority
Shows only one and cannot be selected as other boot device
1st Boot Device [HDD:SM-STXXXXXXXXXXX]
Can anyone help me on this.
Network connection is ok. both device can ping each other.
one pc ip address is 192.168.1.5
mini pc ip address is 192.168.1.6
default gateway for both device is 192.168.1.1 (connected to a switch)
is there any commands i can use in command prompt to tell my cd to boot to mini pc machine VIA ip address ??
I know is much more easier to install using a external dvd rom plug into the usb port and start the normal installation. but i dont have one on this point of time..and i dont want to pull out my cd rom drive out from my working pc then plug it to my mini pc just to install OS on it.
I think i am too adventurers.. not too sure if this can be done.. but actually i have puppy linux install on the mini pc using thumbdrive to boot. I just want to try to install this using Windows CE or Windows XP.
Please help me 🙁
Regards
-K2002-
Manufacturer: VIA
FSB Speed: 400 Mhz
Cache L1: 128kb
Cache L2: 128kb
Quick Boot Enabled
Quiet Boot Disabled
Boot Priority
Please help me 🙁
Regards
-K2002-
