Installation help
What makes you think it is compatible with the LGA1155? Does it say it is in the instructions because Newegg doesn't list it as compatible?
I would follow the LGA1156 instructions.
Actually I would return it unless it says somewhere it is compatible with LGA1155.
Strange that Newegg has some of the 1156 that don't include 1155. That made me believe something was different This was one of them that was listed without the 1155.
