Question Installed artic esports 34 duo fans as pull/push(the wrong way for my case fans config) how much does it matter?
java091
View: https://imgur.com/a/BaYHSNP
I installed it like this(back intake), but the rear fan from my case is exhaust. So I have two options, put the rear fan as intake or take down the 2 fans from the CPU cooler and put them the right way(Would be a massive pain in the a**). My temps did indeed improve compared to stock cooler(Went from 60-65C idle to 39-41C and from 90+ under heavy load to 60-64C). Anyway, how much does it affect the temps? Could I be getting better temps If I change the fans direction?
