I am a first time builder, and I have just installed all of my components into my case. I have also wired everything in what I think is the correct place. The problem is, my wire management looks kinda shitty and I am not really sure how to go through the whole boot process.
CM Storm Stryker (stock: 2 x 120mm front, 1 x 140mm back, 1 x 200mm top)...all hooked to stock fan controller
Corsair AX760
Intel Core i5 4670k
Hyper 212 EVO
ASUS Z87-A
Corsair Vengeance LP (2 x 4)
WD Green 2TB
Samsung 840 EVO 250GB
LG Blu-Ray
Windows 8 64-bit
Still waiting to get GPU on Black Friday. Looking for a EVGA GTX760 4GB or something close.
I just have some questions about what to do after everything is in place?
-Should I try to test everything now, or wait until my GPU is here?
-Should I focus on tidying up cables before running first POST? The side panels fit nice, but it just looks kinda shitty back there. Am I just being paranoid about the look of the back of the motherboard?
-My PSU came with SATA power cables with four connectors. I currently have one plugged into each of my 3 drives. Is it okay to use this single cable for all 3 drives, any power ramifications for doing so?
-All components are brand new, I just want to install Windows 8 on the SSD and everything else on the HDD. Is it really that simple? Do I just change the location of where I want things to save everytime? I would only use this PC for gaming and some school work.
Thank You for anyone who reads or responds. Any input is much appreciated
Corsair AX760
Intel Core i5 4670k
Hyper 212 EVO
ASUS Z87-A
WD Green 2TB
LG Blu-Ray
Windows 8 64-bit
