RocknRolliver :
dovah-chan :
If your PC is a prebuilt, you can just look up your model on the manufacturers website and download the appropriate audio drivers from their.
Or if you can't find it/don't know your PC (or motherboard) manufacturer, you can always find out which codec you have and simply do a quick google to find out where to get the drivers for it. The most common codec these days is the ALC 1150.
I downloaded and installed this which seems to be the one I used before.
http://
The Realtek driver still doesn't show up in my audio devices or in device manager. Although I can see that it is on my computer.
I can think of two solutions:
-Use a DVI cable instead of an HDMI one (DVI does not transmit audio signals like HDMI does) therefore disabling your monitor as the default audio device.
-Uninstall
both your GPU drivers (ALL of them; including your HDMI audio drivers) and audio drivers.
Then you reinstall your audio drivers
first and if it does work, reinstall the GPU drivers but omit the HDMI audio drivers (you can install them later in the future if you need to).
For a complete uninstall of both drivers out of your system:
-Go to Control Panel>Programs and Features: uninstall them normally like you would
-Then open go to your Program Files folder (be sure to check both the regular and the X86 one): delete any and all folders relating to Nvidia or Realtek.
-Next go to C:\Users\Default\AppData\ and delete any folders relating to Nvidia and Realtek. Also go to C:\Users\Default\AppData\Roaming
**(Default is a hidden folder so you might have to enable viewing hidden items in order to see it.)
-Now go to C:\Users\your_user_name_here\AppData and go to the
Local and Roaming folders and delete any folders relating to the two aforementioned companies. (Ignore LocalLow if it's there)
-Next, open up the start menu and type in regedit to open up the registry.
-Navigate to HKEY_LOCAL_MACHINE\SOFTWARE and delete any folders relating to Nvidia and Realtek.
-Next go to HKEY_CURRENT_USER\Software and delete any folders relating to them.
-Also go to HKEY_USERS/S-1-5-19/Software and delete any and all folders relating to them. (Feel free to check any of the other S-1-5-XX folders for Realtek/Nvidia folders)
-Restart
-Reinstall drivers
-Restart again
-Profit
