Installed Second Hard Drive won't work
Kevin_6
My first hard drive that has always been installed on the computer was getting full(only 250 GB) So I decided to purchase a second internal hard drive (1TB). After I received it and connected it to my computer a whole problem happened where I believe I marked the new Hard Drive's partition as active and Windows wouldn't boot off the first hard drive. After having fixed this, the second hard drive now won't ever format to NTFS whenever I try. It's seen as Online however it says it is RAW and Healthy (Primary Partition). I can't format it to NTFS and I just can't use the new HD. What do I do to fix it?
