So I bought some AMD 3650s off eBay from a top rated seller he guarantees they are tested and working but used. All of them worked without a hitch except one that I installed on a dell computer, I don't think I have to connect any extra power cords to it because I didn't on the other ones and i don't see a spot for them. I made triple sure that the GPU was properly seated on the motherboard. I installed the AMD catalyst control center driver 13.9 which is for hd radeon 3xxx models. I uninstalled all old drivers first as well. I'm using a VGA to DVI converter and I tried switching that but to no avail. The monitor will work on the integrated GPU but not on the dedicated gpu. Maybe a problem with that particular port on the GPU? Maybe I should get a HDMI to VGA converter and then try it? I googled this but nothing works someone please help. I will try the 3650 on a different PC and get back to you guys but I don't think the GPU is the problem.
