Hello, I've got a -- ASROCK z390 PHANTOM GAMING 7 -- motherboard and would like to install a front-side panel with all the ports availablr from the motherboard, I could use some help regarding the USB versions, the type & amount of each, and the thunderbolt port , etc. to find the correct product from Amazon/New egg/or whatever pc parts store. Here's the info from the User Manual: 1 x Front Panel Audio Connector (15μ Gold Audio Connector)
• 1 x Thunderbolt AIC Connector (5-pin)
• 2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Intel® Z390)
(Supports ESD Protection)
• 2 x USB 3.2 Gen1 Headers (Support 4 USB 3.2 Gen1 ports)
(ASMedia ASM1074 hub) (Supports ESD Protection)
• 1 x Front Panel Type C USB 3.2 Gen1 Header (Intel® Z390)
Here's the link to the user manual: https://download.asrock.com/Manual/Z390 Phantom Gaming 7.pdf
-Thanks, from Keith
-Thanks, from Keith
