Installing a Graphics Card to an OEM PC to run a 4k monitor at 60hz
hewu123
Commendable
Jul 27, 2016
16
I have an OEM PC with no graphics card that has an i5-3330 CPU and it only has two Dual Link DVI ports.
I would like to run a 4k monitor at 60hz. I found out this is only possible with DisplayPort 1.2, 1.3, 1.4 and HDMI 2.0.
How do I make it so my system can connect to a 4k monitor at 60hz.
Will Dual Link DVI work?
Do I need to install a graphics card? If yes, which is the cheapest one I can get so I can connect a 4k monitor at 60hz? I don't play any games so I don't need a gaming graphics card, just one with
DisplayPort 1.2, 1.3, 1.4 or HDMI 2.0, I think?
Is it possible to add a graphics card in an OEM PC without deactivating my windows OEM license?
Do I need to change my power supply? If yes, what is the minimum wattage I need if I add in your recommenced graphics card?
I can't test it out because I don't have a 4k monitor yet.
