Greetings Ladies and Gentlemen,
Background:
I am trying to upgrade the default graphic card of HP Pavilion h8-1160t to ATI 6970. There are two problems. First, the motherboard used in the HP is bad: ipisb ch2. It only works with something below ATI 6000 and Nvidia 600, and it is buggy with anything not default from HP. Second, I have to get a new PSU of 620w bronz from Seasonic to power the ATI 6970.
Problem:
I tried two ATI 6970 in a row with the following result: no signal to monitor. The motherboard does not beep, and I do not know whether the system POST. Here is what I did. I use the on board graphic to get into windows, and from there I plugged in the two 6 pin and 8 pin power cord to the ATI 6970. Windows recognized the 6970 right away, and I installed the driver. However, upon restart there is no signal to monitor again.
Thoughts:
The Seasonic PSU supports the system with an ATI 6570 in place of the ATI 6970 fine. Before I plugged in the two 6 pin and 8 pin power cord to the 6970, windows does not recognize anything in the PCIE slot. So, I think at least one of the 6 pin or 8 pin is working, so that the 6970 does draw power from the PSU. But, I do not have another card to be sure.
The chance of both 6970 dead on arrival is slim, and the computer does recognize the card in windows. So, I think the 6970 is also working. But, again I am not sure, since I do not have another system with enough power for the 6970.
I do not know what is the problem. Any suggestion is appreciated.
Thanks and Regards,
Xiang
Background:
Problem:
Thoughts:
Thanks and Regards,
Xiang
