So this is my very first build, and for the case I am going to be using the NZXT M59 case. It's a very nice case for under $60 and has everything I want and need. I just have a couple questions:
1) I want to install 4 Blue LED fans in the case (1 in the front, 1 rear, and 2 on the top). The fan I will be using is the Enermax 120mm Blue LED fan: http://www.newegg.com/Product/Product.aspx?Item=N82E16835214029
Will there be sufficient space for all the fans? I'm more concerned for the top fans, because I will be using a Hyper 212 EVO. I can't install a 140mm fan in this case right?
2) If I would want to upgrade to a water cooling system such as the Corsair H60 in the future would I be able to do that with this case?
I would really appreciate your responses! Thanks in advance guys!
PC Specs:
Intel i5 3570k CPU
Hyper 212 EVO CPU Cooler
Gigabyte Z77X-D3H Motherboard
G. Skill Ripjaws X Series 8 GB DDR3-1600 RAM
Western Digital Caviar Blue 1 TB HDD
MSI GeForce GTX 660 TI PE OC
Seasonic M12II 620w PSU
ASUS DVD/CD Writer
PC Specs:
Intel i5 3570k CPU
ASUS DVD/CD Writer
