Dynomite54 Reputable Jan 14, 2016 550 0 5,160 May 24, 2016 #1 I need some help installing DSL on to a 128mb hard drive form a usb. How do I do it?
esco_sid Splendid May 11, 2012 2,723 1 21,965 May 24, 2016 #2 you make a bootable usb ?? Upvote 0 Downvote
Dynomite54 Reputable Jan 14, 2016 550 0 5,160 May 24, 2016 #3 esco_sid : you make a bootable usb ?? yes Upvote 0 Downvote
esco_sid Splendid May 11, 2012 2,723 1 21,965 May 24, 2016 #4 Dynomite54 : esco_sid : you make a bootable usb ?? yes then plug it in boot from it and install Upvote 0 Downvote
azaran Splendid Feb 17, 2010 3,594 0 26,960 May 25, 2016 #5 Also check out Yumi, its a great little utility that helps you build bootable USBs for various purposes. Bootable linux installs being one of them. http://www.pendrivelinux.com/yumi-multiboot-usb-creator/ Upvote 0 Downvote
Dynomite54 Reputable Jan 14, 2016 550 0 5,160 May 25, 2016 #6 esco_sid : Dynomite54 : esco_sid : you make a bootable usb ?? yes then plug it in boot from it and install Thats the thing have you ever used Damn Small Linux there is no install to hardrive option Upvote 0 Downvote
Dynomite54 Reputable Jan 14, 2016 550 0 5,160 May 25, 2016 #7 esco_sid : Dynomite54 : esco_sid : you make a bootable usb ?? yes then plug it in boot from it and install Thats the thing have you ever used Damn Small Linux there is no install to hardrive option Upvote 0 Downvote
Dynomite54 Reputable Jan 14, 2016 550 0 5,160 May 25, 2016 #8 azaran : Also check out Yumi, its a great little utility that helps you build bootable USBs for various purposes. Bootable linux installs being one of them. http://www.pendrivelinux.com/yumi-multiboot-usb-creator/ Yep I have been using that tool Upvote 0 Downvote
azaran Splendid Feb 17, 2010 3,594 0 26,960 May 25, 2016 #9 Looked at the sites info on installing to a hard drive? http://www.damnsmalllinux.org/f/topic-3-26-18529-0.html Upvote 0 Downvote
Dynomite54 Reputable Jan 14, 2016 550 0 5,160 May 25, 2016 #10 azaran : Looked at the sites info on installing to a hard drive? http://www.damnsmalllinux.org/f/topic-3-26-18529-0.html Yes I have but they dont work I am just about to try it Upvote 0 Downvote
