Dear all
i just got a new pc . the guy who put all the components together i think he made a mistake
i have the Thermaltake water cooling 3.0 ultimate (the one with 3 fans)
and nzxt 450 Noctis
the upper part of the case there is 3 big holes for the fans...so what he did was he put the radiator then he put the fans from the top of the case..so (radiator and then the part of the case that has 3 holes and then the fans ..is that correct...i guess the hot air is going inside the case not outside ...
and if that is wrong can i reinstall the cooling system one more time (removing and then installing it again ) ?
thanks in advance
and nzxt 450 Noctis
thanks in advance
