Archived from groups: alt.games.unreal.tournament (More info?)
Hi
I've done this about a million times before, and nothing hardware has
really changed. Installing Totally Unreal (Europe, pre-patched to 436,
original) on XP on a 768MB xp2400.
Fresh install. However, every attempt ends with a critical erro part-way
through decompressing the maps. DecompressLength <= MAX_BUFFER_SIZE+1
Tried to install on a 60G and a 40G, ntfs and fat32. The latter has
worked before, and isn't the problem with too big a disk that ut's
installer has had before.
I *think* this may be related to a bunch of error messages regarding
memory that I'm getting from other apps about being unable to "read" or
"write" memory, and I'm suspicious of some XP hotfixes. However, trying
to remove one suggested by a forum post on a website made XP unable to
boot and I had to reinstall... (Great fun)
Before you ask, the RAM on this machine is fine, as is the rest of the
hardware (I'm 99% sure). nVidia chipset, home built.
Anyone come across something similar? I wanted to reinstall to start
from scratch again, my current ut having got a tad bloaty...
Thanks!
Flash
Hi
Thanks!
Flash
