I am creating my first (and second) builds and im using the same 700w 80+ bronze certified PSU for both since it comboes with components from both builds making it very cost efffective. However it says that it comes with
20+4 PIN 1 (600mm) x 1
CPU (4+4) 1 (650mm) x 1
6+2 PCI-E 4 (550mm+150mm) x 1
SATA 6(450mm+150mm+150mm) x 2
4 pin Peripheral x 3
FLOPPY x 1
and unless i'm mistaken I will need 2 Pcie 6 pin header for one build (gtx 970) and 2 8 pin headers for the other (r9 280x). am i right? are there any other ones i will need? where can i find them? or should i look for another PSU?
heres the link to the PSU http://www.newegg.com/Product/Product.aspx?Item=N82E16817116032
FLOPPY x 1
