Kinda new here, hoping you guys could help, some of you might've already experienced the same thing.
Problem is my fan stopped spinning. The gpu detects the temps but it won't ramp up the fans even when it's already at around 90°C, and my only solution was to create a custom fan profile in MSI Afterburner. It will not spin at 50-70% fan speed but only at max 100%, and it spins like a turbine. One of the fans starts spinning at 80%. What I did was to set the fan speed to 100% once it reaches 55°C because if I set it too high, it will turn on & off really hard; my max temps when playing is 65-75°C.
Is there a way around this? When I'm in BIOS the fans are completely dead and there's no way for me to ramp up the fans since I use afterburner to control it. Worst part is when I'm installing windows, the fans are dead and it's so hot enough to burn your skin, and the system crashes with my Windows installation gone. I had to point a USB powered blower fan to cool it while installing windows, till it was successful.
What I have in mind right now, is to plug in the GPU fans to the MOBO PWM header, and control it. Problem is there's no setting in my BIOS that shows it could monitor GPU temps. Second is to buy a pwm fan header with an independent heat sensor probe, and stuck it in the GPU heat sink. Plug in the GPU fans there, and that'll prolly solve my problem.
If you have any other ideas please let me know. Thanks!
