Insufficient power ?
INeedKeyboardHelp
42
Hi guys, I am having an issue
Every once in a while, more often now, my computer will freeze and display random white pixels as if they were dead pixels, is this due to insufficient power to my GPU? My build is only a week old, I am using an r9 280 and a Seasonic 620w M12II, and this power supply's PCI-E cables are split, as in one slot on the psu has 2 6+2 pin connectors. On the manual, it says to connect only one cable (a 2x 6+2 cable) to a <225w TDP GPU. Should I try to connect two 2x 6+2 cables and only use one six pin per cable? Thus using both of the PSU's PCI-E connectors? Thanks
If it booted you are fine. Check the windows event log
http://www.sevenforums.com/tutorials/226084-event-viewer-open-use-windows-7-a.html
No, you should refer to your motherboard manual as to where the RAM should be. Freezing can be caused by : Overheating, program error(inefficient memory dump/usage), hardware malfunction(often due to overheating). Running single channel is not a problem but its not efficient(I honestly don't know if having 1 stick in ram can cause a crash). When does your computer freeze? during gaming? (During heavy load or resource use?) tell me as much as possible. My theory is that you are gaming and once the video card is trying to pull data, your RAM bottlenecks and craps out on you causing a crash, or you are overheating.
Well, my computer freezes only when idling while browsing, light programs, downloading steam games, but never during gaming. Also, my gpu isn't even detected by my BIOS, as there is no tab for it or anything that says "graphics processing unit" or "gpu clock speed"
Yeah that points to no overheating. I'd say get the exact same stick of ram that you have, refer to your motherboard manual where to stick it in (Usually same color coding is where the other one should be) and get back to us.
I may have found the issue to be a physical issue: My CPU cooler (Hyper 212 EVO) is touching my side panel, I know that this component should not be carrying any charge, but with my side panel taken off, it does not seem to be freezing anymore. Kind of a long shot, I know, but maybe the cooler is picking up a charge from somewhere via the diffusion of electrical charge between two objects, such as the CPU
Nevermind my last post^, it froze again with the case side off, there is nothing in the event log besides the critical error when I have to force shut down the computer by holding the power button down(I know this is bad practice as well, but i cannot do anything while it's frozen)
He's not having GPU problems. his system freezes on idle.
Freezing on idle is most commonly a driver issue or sleep settings or low power states issue, not overheating issue. Pixelated displays are most commonly a gpu vram issue, but can also cause a system to hang up. As can a hdd. There are various possibilities, but overheating at idle isn't one of them.
This isn't a question of 'what' to fix, its a question of eliminating 'possible' causes, in an attempt to narrow down the culprit.
The screen does not pixelate like you would normally think of it; just a few pixels turn white and they are few and far between, maybe 20 total across the whole screen
