I dropped the CPU temp 1.5ºc by raising my fan approx. 5cm above the hs.
You probably already know that some fans blow in a funnel shaped pattern so by raising the
fan on my MCX-462, it made the air focus more to the center of the hs. I am using a Ultra
high speed 80mm Sunon instead of the Delta that came on it. I have it fastened to a rheostat
so I was able to turn it down even quieter. I used rubber washers to raise the fan so it also
dampened the vibration. Pretty "cool".
<b><font color=red>Caution!...</font color=red><font color=blue> Firesuit...Ear Protection...Hardhat Area!</font color=blue></b>
