inte pc build
jubimaan
34
This PC good enough for CSGO at 4:3 low settings @ 144hz?
Intel Pentium G4560 3.5GHz Dual-Core Processor
ASRock H110M-HDS Micro ATX LGA1151 Motherboard
Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2666 Memory
gtx 660
power: cx600
Is this enough good to play csgo without lags? I want to play with 144hz so I want my fps to be stable over 144. ) I have amd fx8320 but have weird fps drops and lags on smokes/molotovs. thx for the answers. if that is not enough to run csgo with 144hz monitor, tell me good builds.
U have underforstod it, its nothing close to what u say.
However if you going to buy a brand new cpu go for the latest generation (skylake, kabylake, ryzen)
Also i always recommend getting second hand parts if you dont have enough money. You may look for it.
Those fps dips can be caused by many other things not only cpu, this why i told u to monitor everything while u gaming.
Are you aware that any H110 motherboard may not support that CPU out-of-box? If you get one that does not have newest BIOS already installed (and so far most shipped do not), you will not be able to make it work together. And for upgrading the BIOS yourself you need SkyLake CPU.
Its not worth it because fx8320 should be faster, u will have to buy new motherboard and ram beside g4560.
I think 660 holding you back, you may want to upgrade it first.
Im just wondering if my fx 8320 has damaged someway cause I am issuing really low fps suddenly. my fps was all good months ago. and csgo Is processor heavy game. People keep saying gpu wont help me to pull more fps there.
ya I think im going to buy i5 4690k, I have tried to overclock, but it doenst help. btw people are saying my amd fx8320 and motherboard are not the best partners together what do you think?
motherboard: msi 970a-g46
cpu: amd fx 8320
is there any chance my performance would go better with better mobo?
unless u not going to buy brand new i5 4690k its a good deal. Show me who said that, your performance wont be better.
Btw what u can do is monitor cpu gpu usage during gameplay, i know CSGO is cpu demanding game but still 660 is pretty old.
Try to update drives too.
well I cant find the thread where I asked about but the answer was something like that my cpu is 125w and mobo is 90w. I was planning to buy brand new i5, but I really dont know what to do now. IM just confused. I need new specs asap.
