N nenadilievski72 Commendable Mar 5, 2018 195 0 1,680 Sep 1, 2018 #1 Lets say i have gpu with only dvi ports, and monitor with only vga port. Is there a way to use the gpu that is Integrated in the motherboard for output, but run apps/games on external gpu?
Solution WildCard999 Sep 1, 2018 No, but you can use a DVI to VGA active adapter for your GPU to the monitor.
WildCard999 Titan Moderator Jul 18, 2014 21,771 1,935 93,640 Sep 1, 2018 Solution #2 No, but you can use a DVI to VGA active adapter for your GPU to the monitor. Upvote 0 Downvote Solution
