I just started having these problems myself. Same motherboard by the looks of it as well. Couldnt get the computer to start... recovery disk said badsectors on HDD so i replaced that... installed new windows and it wouldnt boot. I then removed my relatively new HIS 7850 GPU and then ws able to load windows(Graphics card was having trouble starting the fan anyway). Noticed that the onboard GPU was really ho after taking out by 7850.
Now I dont know what to do... Does this mean the MOBO is failing. What are the options?
I this is a rather old post but if you solved this could you tell me what you did to fix it?
