Integrated graphics turned on, don't POST anymore, and DRam light stays on. HELP!
Aug 1, 2018
I've had this computer for a year now:
Z170 SLI PLUS
16GB RAM
1060 GTX
i3 6100
Etc.
Recently I've been into streaming and read that I could get faster render speeds if I turned on integrated graphics.
I turned it on and there was an option to give it a memory share..
Since I have ram to spare, I went ahead and gave it 1024mb of ram.
Pc won't boot or post now, dram And the mobo DRAM light stays on.
(Update: it starts with the DRAM light on... after a while the DRAM Light goes off and the CPU light goes on)
I tried switching slots and nothing (I have 2 dimms, tried one, etc...)
Gonna try removing the GPU now..
Any tips on how to solve this?
Or in a last case scenario, how to restore MOBO to previous configuration?
Thanks in advance!
Your issue has occurred since adding more RAM.? If this is the case then remove what you added and clear your CMOS. This will bring Bios back to default which may now be corrupt. If still no go then reflash Bios.
List the 16GB of RAM by part No.? Do not mix DIMM modules.
If again no go then remove your graphics card and test with IGPU.
