P PROTEGE1 Commendable Jan 8, 2017 2 0 1,510 Jan 8, 2017 #1 Hi, Dell is telling me that their integrated batteries are soldered onto the motherboard and I need help. I want to know if a laptop will work with a power adaptor when its integrated battery is removed. Thank you!
Solution ffg7 Jan 8, 2017 battery is not soldered to motherboard but plugs into motherboard. http://www.dell.com/support/manuals/ca/en/cabsdt1/inspiron-15-7559-laptop/inspiron-15-7559-laptop-v1/Procedure?guid=GUID-737A9126-D397-408B-8DCF-07AAA1B2A3D7&lang=en-us http://topics-cdn.dell.com/pdf/inspiron-15-7559-laptop_Service%20Manual_en-us.pdf
Barty1884 Retired Moderator Apr 16, 2015 22,254 1,355 108,740 Jan 8, 2017 #2 IF you can safely remove the battery (if soldered, it'll be difficult), most laptops will work via the power brick only. Which model are you dealing with specifically? Removing an integrated battery is tough Upvote 0 Downvote
ffg7 Judicious Apr 7, 2015 5,924 2 34,665 Jan 8, 2017 #3 normally yes. what battery as in the main battery or the cmos battery? what is the make & model# of the dell laptop Upvote 0 Downvote
P PROTEGE1 Commendable Jan 8, 2017 2 0 1,510 Jan 8, 2017 #4 Thank you for the replies. I am looking at the newest model for Dell's Inspiron 15 7000. http://www.dell.com/en-us/shop/productdetails/inspiron-15-7567-laptop It is a new version. I feel like they would not have soldered it in especially after looking at youtube videos. Anyone have any insights? Thank you again. Upvote 0 Downvote
ffg7 Judicious Apr 7, 2015 5,924 2 34,665 Jan 8, 2017 Solution #5 battery is not soldered to motherboard but plugs into motherboard. http://www.dell.com/support/manuals/ca/en/cabsdt1/inspiron-15-7559-laptop/inspiron-15-7559-laptop-v1/Procedure?guid=GUID-737A9126-D397-408B-8DCF-07AAA1B2A3D7&lang=en-us http://topics-cdn.dell.com/pdf/inspiron-15-7559-laptop_Service%20Manual_en-us.pdf Upvote 0 Downvote Solution
