Intel 2700K integrated problem
mark12000
106
Hello! I am sending my GPU back, so until I get another back I still want to be able to browse the internet and so on but without safe mode i cannot get past the booting screen! I can here the login sound but the screen is just black. Anyone know a solution?
Yes and Yes. (Plugged in using HDMI)
Do you mean set to default settings?
Just ran it as default nothing changed, ran it as default with primary graphics as onboard nothing changed, ran it as i usually do with primary graphics as onboard and nothing changed.
Weird... Could it be the actual display port on your MoBo? It should change, Any kind of adapter you using?
what do you mean display port? what should change? and I am not using an adapter. I just reset the motherboard but that also didn't work.
You mean you did a CMOS reset? Are you sure you did it correctly? That should have worked.
