Question Intel 945GME extend and clone monotor issue
Oct 3, 2019
Hello everyone!
This is my first post on Tomshardware. I hope I have sorted my problem in the correct category.
I have a G5C900-B board (Datasheet can be found here) with integrated Intel 945gme chipset. Unfortunately the hardware cannot be replaced so easily and must now be updated from Windows 7 to Windows 10. The update process worked great except for the graphics driver. The system has two proprietary monitors (lvds) connected to the chipset and now they only work individually and no longer in extended or clone mode.
The system was configured with Windows 7 and the version 6.14.10.4926 of the Intel driver. With Windows 10 I used the latest driver 8.15.10.1930. I also tried to install the old driver which worked fine with Windows 7 now on Windows 10 (adjusted the inf file in setup). It installed but crashed with a Code 37 error. The problem is that Windows 10 shows me that it has detected two monitors but when switching on the clone or extended mode the screen flickers for about 1 second and then automatically switches back to single screen. I hope someone has ideas for me what I could try....
Excerpt from: msinfo32 /report
Element Wert
Name Mobile Intel(R) 945 Express Chipset Family
PNP-Gerätekennung PCI\VEN_8086&DEV_27A6&SUBSYS_27AE8086&REV_03\3&2411E6FE&1&11
Adaptertyp Nicht verfügbar, Intel Corporation-kompatibel
Adapterbeschreibung Mobile Intel(R) 945 Express Chipset Family
Adapter-RAM Nicht verfügbar
Installierte Treiber igdumd32.dll
Treiberversion 6.14.10.4926
INF-Datei oem6.inf (Abschnitt i945GM1)
Farbebenen Nicht verfügbar
Farbtabelleneinträge Nicht verfügbar
Auflösung Nicht verfügbar
Bits/Pixel Nicht verfügbar
Speicheradresse 0xFEB80000-0xFEBFFFFF
Treiber c:\windows\system32\drivers\igxpmp32.sys (6.14.10.4926, 5,58 MB (5.854.752 Bytes), 15.02.2008 12:12)
PNP-Gerätekennung PCI\VEN_8086&DEV_27AE&SUBSYS_27AE8086&REV_03\3&2411E6FE&1&10
Adaptertyp Intel(R) GMA 950, Intel Corporation-kompatibel
Adapter-RAM 256,00 MB (268.435.456 Bytes)
Installierte Treiber iegddis.dll
INF-Datei oem6.inf (Abschnitt i945GM0)
Speicheradresse 0xFDF00000-0xFDF7FFFF
E/A-Port 0x0000FF00-0x0000FF07
Speicheradresse 0xD0000000-0xDFFFFFFF
Speicheradresse 0xFDF80000-0xFDFBFFFF
IRQ-Kanal IRQ 16
E/A-Port 0x000003B0-0x000003BB
E/A-Port 0x000003C0-0x000003DF
Speicheradresse 0xA0000-0xBFFFF
Thanks for your help!
Why you had to upgrade ten-years old computer to Windows 10 if it was used for a specific task?
I suppose your only solution is to go back to supported system. And "The hardware cannot be replaced so easily": That motherboard someday WILL die. Make sure you have contingency plan in place.
Oct 3, 2019
The thing is that the device will be replaced by the end of 2020, because there is a major upgrade planned. Also we have more than enough spare parts to maintain the old system therefore it would really hurt...
