Question Intel AX200 Problems
Oct 14, 2020
I currently using a Comfast AX200 WiFi adapter; On the first startup after shutting down, the adapter isn't recognized by Windows. This is fixed by hot-swapping the adapter from Slot-1 to Slot-2 then restarting, but, this isn't healthy for the system, and i'm afraid it may damage the PCI-E. I have installed the chip-set drivers, and the AX200 drivers, but nothing has solved it yet. Any solutions are helpfull.
BTW, my chip-set is AMD A320, the AX200 driver version is 21.120.2.1, and the chip-set driver revision number is 2.07.14.327
