Intel Cooler help needed!
SirSamuel
26
Intel Core i5-4590 3.3GHz Quad-Core Processor
What kind of cooler should I get and why should I get it. Also... Thermal paste???
You should not need one. The stock cooler is designed to be capable of cooling the CPU at stock speeds. Since your CPU has very little overclocking capability anyway (a small increase in bclock may be possible), unless 1) you're in a hot environment and 2) you're working your CPU particularly hard, you shouldn't need another cooler. An additional case fan to make sure you have good flow through your case would likely be more effective.
Since you will not be overclocking, the only reason for a different cooler would be to reduce noise. Be aware that the stock Intel cooler is fairly quiet.
You would probably find a less-expensive 92mm cooler sufficient. If you want to get a 120mm version, avoid the Hyper212 EVO unless you have discount coupons. It's not a bad cooler, but is a bang/buck Loser. Competitors offer similar performance (within 1C-3C) but typically for 30%-40% less.
So in conclusion, No, I don't need one. Correct.
and face no problems really?
Oh and last thing. Thermal paste I should use always correct? Even without cooler?
The stock Intel stock coolers have paste pre-applied. One time use only though. And they are not that quiet. My temperatures dropped in the neighborhood of 10C , when I changed out mine.
But you can start with the stock cooler and then change it out later. It can be a pain to get the stock cooler off. One of the twist-to-tighten connectors on mine refused to release.
