K kahfi Reputable Jun 25, 2015 2 0 4,510 Jun 25, 2015 #1 is it possible for my pc to run 64 bit? my processor : intel core 2 duo cpu e7500 @2.93ghz (2cpus), ~2.9ghz
Solution spdragoo Jun 25, 2015 http://windows.microsoft.com/en-us/windows7/products/system-requirements You should be fine for Windows 7. http://www.technize.net/how-to-check-if-your-processor-supports-pae-nx-and-sse2-for-windows-8-installation/ This will help you see if you can handle Windows 8.1 (&, by extension, Windows 10).
jaguarskx Titan Apr 19, 2006 27,976 3 84,965 Jun 25, 2015 #2 You can run 64-bit programs as long as you have a 64-bit version of Windows installed. Upvote 0 Downvote
K kahfi Reputable Jun 25, 2015 2 0 4,510 Jun 25, 2015 #3 jaguarskx : You can run 64-bit programs as long as you have a 64-bit version of Windows installed. Windows 7 or xp? Upvote 0 Downvote
jaguarskx Titan Apr 19, 2006 27,976 3 84,965 Jun 25, 2015 #4 Between those two you are better off with Windows 7 64-bit. Windows XP 64-bit does not have very good 64-bit driver support for devices like printers, routers, etc. since most manufacturers ignored that OS. Upvote 0 Downvote
spdragoo Splendid Ambassador Oct 17, 2011 3,166 8 27,115 Jun 25, 2015 Solution #5 http://windows.microsoft.com/en-us/windows7/products/system-requirements You should be fine for Windows 7. http://www.technize.net/how-to-check-if-your-processor-supports-pae-nx-and-sse2-for-windows-8-installation/ This will help you see if you can handle Windows 8.1 (&, by extension, Windows 10). Upvote 0 Downvote Solution
jsmithepa Polypheme Jun 14, 2014 13,091 264 60,840 Jun 25, 2015 #6 Can a 32 bit processor run Windows 64? Upvote 0 Downvote
G GhislainG Titan Jul 16, 2008 23,934 5 74,965 Jun 25, 2015 #7 jsmithepa : Can a 32 bit processor run Windows 64? That wasn't a serious question, was it? Upvote 0 Downvote
